Warning Lights - Dash
FORD
TIM_DUKE
Have a Ford 450 on a class C motor home... 2000 v10. Had a short in the trailer lights which I corrected and all of the lights are fine. Both the Brake and ABS warning lights are still lit on the dash. Breaks are fine and tested the ABS... How do I re-set the sensor for these two warning lights?
Tim
Jun 11, 2007 at 1:14 PM
MIKE H R
  • 3,094 POSTS
you can try to disconnect the negative side of the battery, leaving it off for a few minutes then reconnecting it. The computer will not reset itself until the vehicle has been driven about 50 miles.
Jun 11, 2007 at 6:39 PM
