Ford Focus SE Ignition Won't Turn
FORD
OUT671
My cars fix engine light came on and i took it to jiffy lube they said i had a code 1406 i checked it out over the internet and found out that it deals with my engine's emission system he told me that same hoses were loose and he put them back on the same day at night the light came on again i took it back to them and they said its the same thing and they can't do anything about it so i searched the internet and found out what it means my downstream hose was unplugged or plugged (obstruction) or my catalytic converter was messed up and the accumulation of pressure is unpluggin the hoses --- i have a rattling noise when i speed up plus my car is having difficulty increasing speed so do you think i need a new catalytic converter ???? or what is the problem with my car.
Mar 31, 2006 at 5:23 PM
LOSONE
  • 1,616 POSTS
What kind of car, engine, mileage etc. Ford warranties the emission system for 5 years 60K miles
let me know
Mar 31, 2006 at 11:15 PM
OUT671
ford focus se 4 door sedan 85,000 no warranty and the ignition cylider now won't turn its locked itself. so what can i do about that too ???????
Apr 1, 2006 at 9:04 AM
LOSONE
  • 1,616 POSTS
I don't think the key is locked but the steering wheel lock is in a bind. Grab the wheel hard and turn it one way or the other to a small (about 1/2degree)jiggle it while trying to turn the key. I have seen it quite a few time on the little focus
Apr 1, 2006 at 9:12 AM
OUT671
its not working can a locksmith fix it because the dealership is going to charge me like 500 bucks because i don't have worry :( what can i dooo ???????
Apr 1, 2006 at 9:53 AM
LOSONE
  • 1,616 POSTS
It's worth a try, a service call is a lot cheaper than the dealer especially is he can twist the wheel and unlock it. I still think that's the problem. Let me know
Apr 2, 2006 at 1:06 AM
Suggested Repair
The ignition concern is likely a bound steering-wheel lock, not a failed cylinder. Grip the wheel firmly and jiggle it about half a degree either way while turning the key. If that does not free it, a locksmith service call may be cheaper than the dealer and may release the lock. Code 1406, the rattle, and the power loss were not diagnosed; emission coverage was noted as 5 years or 60,000 miles, and this Focus is at 85,000 miles with no warranty.
Conversation Summary
A Ford Focus SE owner reported a check-engine light with code 1406 after loose emission hoses were reconnected, plus a rattle and poor acceleration, and asked whether the catalytic converter was bad. The car has 85,000 miles and no remaining emission warranty. The owner then said the ignition would not turn. The expert said the steering-wheel lock is likely binding, advised jiggling the wheel slightly while turning the key, and suggested a locksmith may cost less than the dealer if that does not work.
