Ford Focus SE Ignition Won't Turn
let me know
Suggested Repair
The ignition concern is likely a bound steering-wheel lock, not a failed cylinder. Grip the wheel firmly and jiggle it about half a degree either way while turning the key. If that does not free it, a locksmith service call may be cheaper than the dealer and may release the lock. Code 1406, the rattle, and the power loss were not diagnosed; emission coverage was noted as 5 years or 60,000 miles, and this Focus is at 85,000 miles with no warranty.
Conversation Summary
A Ford Focus SE owner reported a check-engine light with code 1406 after loose emission hoses were reconnected, plus a rattle and poor acceleration, and asked whether the catalytic converter was bad. The car has 85,000 miles and no remaining emission warranty. The owner then said the ignition would not turn. The expert said the steering-wheel lock is likely binding, advised jiggling the wheel slightly while turning the key, and suggested a locksmith may cost less than the dealer if that does not work.
