1996 Lincoln Continental ABS Noise
FORD
RLFALLON
1996 Lincoln Continental, 105 K miles. 4.6 liter. A couple of weeks ago i noticed driving in the snow that when the traction control kicked in i would hear a loud fast clicking noise coming from engine compartment. It seems that the traction control is working, but i never had this noise before.
Also when i went to brake on snow i got a very loud crunching / clicking noise and my brake pedal vibrated and the front wheels locked up and i had no control over the brakes.
I just had all new OEM rotors, Calipers, and pads replaced on all four wheels. The brakes work perfect in dry weather but i did notice when i do a panic stop i get that crunching / clicking noise and the brakes act like they don't want to stop and fade real bad.
What do you think the problem is ?
Feb 26, 2007 at 12:10 AM
MATHIASO
  • 1,209 POSTS
Have it scaned or do you get flash codes?
Or something may have happened to the abs system while working on the brake system.
get the codes and get back .
Try driving 2000-4000 miles to "break-in" the new parts...
Feb 26, 2007 at 1:06 AM
RLFALLON
The ABS light on the dash does not come on at all and i checked the fuse and it is ok, I even replaced the fuse with a new one.
Feb 26, 2007 at 1:21 AM
LITTLEBIGBRONCO
  • 9 POSTS
when they did the brakes if they didnt lube the calipers slides they will click and make crunch or a popping sound or the caliper bolts are loose as for the fading peddle the brakes sound like they need to be bleed again or a bleeder on the caliper could be loose or it could be the brake master is bad
Feb 26, 2007 at 1:48 PM
MATHIASO
  • 1,209 POSTS
Yes That could be the case. recheck the caliber and rotor and add a light film of brake grease on the anchor points where the caliper and pads rest. make also sure to aplly light layer of high-temoerature or brake grease to the threads of the star wheel assembly and the washers.
https://images.2carpros.com/forum/automotive_pictures/46384_scan0001_1.jpg
Feb 26, 2007 at 2:52 PM
Suggested Repair
Scan the ABS system for codes. Recheck the calipers, rotors, and pad hardware; apply a light film of brake grease at the anchor points and high-temperature grease on the star-wheel threads and washers. Confirm the caliper slides and bolts are secure, then bleed the brakes again and check for a loose bleeder or a failing master cylinder. Allow the new brake parts some break-in mileage.
Conversation Summary
A 1996 Lincoln Continental with new rotors, calipers, and pads makes a fast clicking noise when traction control engages and a loud crunching or clicking noise with pedal vibration, front-wheel lockup, and fade during snow or panic stops. The ABS light stays off and the fuse is good. Advice was to scan for ABS codes, recheck and lubricate the caliper hardware, bleed the brakes, and inspect for a loose bleeder or bad master cylinder.
