2007 Other Ford Models
2007 FORD
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
DEMETRIUS BROWN
a few weeks ago the engine on my explorer sport trac was whining it sounded like a pulley was going bad & after a little while it stopped, but now if im coasting below or at 1500 rpm the engine will get stuck at 1500 rpm & just make a lot of noise just burning gas. what is going on & how do i fix it?
Feb 16, 2010 at 12:35 AM
MICKEY-D
  • 304 POSTS
I don't think the two are related, just coincidence. The noise was probably a belt noise, or alternator with a load on it. The high idle is probably your throttle cable sticking or binding a little, or you have a bad, or out of adjustment TPS. ................mickey-d
Mar 2, 2010 at 2:56 AM
DEMETRIUS BROWN
[quote:6d17455f61="mickey-d"]I don't think the two are related, just coincidence. The noise was probably a belt noise, or alternator with a load on it. The high idle is probably your throttle cable sticking or binding a little, or you have a bad, or out of adjustment TPS. ................mickey-d[/quote:6d17455f61]
thanks a lot sir. but do you think this is a "do it yourself job" or it needs to be done by a professional?
Mar 11, 2010 at 1:57 PM
MICKEY-D
  • 304 POSTS
I would take it to a parts store and have them scan it for codes. Most places will do that free of charge, hoping you will buy the needed parts from them. Good luck.
....................mickey-d
Mar 11, 2010 at 2:38 PM
