1996 Other Ford Models back door
1996 FORD
ITSONLYME
Interior problem
1996 Other Ford Models Manual 57,000 miles
My back passenger side doot does not open as the bar has seperated from the handle so there's no tension and i can't open it whatsoever so i need to know how to remove the back seats to gain more access into removing the door panal but i can only find 1 screw to undo to remove the door panal, please can you help me. Thank you so much
Oct 16, 2008 at 8:03 PM
2CARPRO JACK
  • 11,533 POSTS
need to know what kind of vehicle it is.An SUV the bolts are usually under the seat to remove it.A passenger car has push locks under the leading edge of the seat near the outer sides.The door panels have pop in clips that hold them on.They have to be popped out for removal. Look for plugs hiding screws at the door handle and behind the bezel around the interior door release
Oct 17, 2008 at 1:16 AM
