1987 Other Ford Models engine control module wiring relay
LARRY62882
  • 21 POSTS
Ok we tried something we ran a wire from coil to black wire with red stripe under fuse box we have fuel pumps working but will not start have fuel to fuel rail but acts like injectors no pushing fuel out to cylinders ty larry it has a pk1 eec in the car
Wednesday, April 14th, 2010 AT 11:22 PM
RACEFAN966
  • 5,029 POSTS
OK did you check to see if the injectors are getting power? If not please do that they may not be getting the signal to open. If they are not we may need to check the computer.
Thursday, April 15th, 2010 AT 8:21 AM
LARRY62882
  • 21 POSTS
Both wires on the injectors are hot both wires to injectors have power going to them but no pulsing from either wire. With or without cranking motor over
Thursday, April 15th, 2010 AT 7:22 PM
LARRY62882
  • 21 POSTS
I HAVE POWER TO ALL THE FUEL INJECTORS BOTH WIRES HAVE POWER TO THEM. THERE IS NO PULSING FROM THE INJECTOR WIRES WHEN IGNITION IS ON OR WHILE IT IS BEING CRANKED OVER ISNT THERE SUPPOSE TO BE LIKE A PULSE WHEN INJECTORS ARE SQUIRTING OUT FUEL
Thursday, April 22nd, 2010 AT 1:08 AM
LARRY62882
  • 21 POSTS
Ok have you closed your site havent heard from anyone for the last to questions ty larry
Sunday, April 25th, 2010 AT 4:45 PM
