1996 Other Ford Models engine identification
1996 FORD
TUMBLEWEEDTURKEY
  • 5 POSTS
Engine Mechanical problem
1996 Other Ford Models 4 cyl Front Wheel Drive Automatic
96 mystique has motor with head casting number
RF-978M-6090-R74 16v zetec VCT manufactured in 97 Which repair book do I buy??????? cant find variable cam info.. its out of time thank you
Sep 16, 2010 at 6:51 AM
WRENCHTECH
  • 20,761 POSTS
That's most likely a DOHC 2.0 VIN#3. That requires special tools to time it correctly and cannot be done without them or it will cause a repeating PO340 code and barely run.
Sep 16, 2010 at 6:56 AM
TUMBLEWEEDTURKEY
  • 5 POSTS
Which repair manual do I buy??????
The engine doesnt belong to that year and make.
Sep 16, 2010 at 7:17 AM
WRENCHTECH
  • 20,761 POSTS
Yes it does. It's factory original for that car.
Sep 16, 2010 at 7:20 AM
TUMBLEWEEDTURKEY
  • 5 POSTS
niether does haynes
Sep 16, 2010 at 7:22 AM
WRENCHTECH
  • 20,761 POSTS
I don't know what your referring to but that is an original equipment motor for that car.
Sep 16, 2010 at 7:24 AM
TUMBLEWEEDTURKEY
  • 5 POSTS
chilton and haynes for that car has nothing on variable cam timing
Sep 16, 2010 at 7:26 AM
WRENCHTECH
  • 20,761 POSTS
What do you want me to say? The motor is original. You can buy an Alldata online subscription for one vehicle very inexpensively. www.alldata.com
Sep 16, 2010 at 7:29 AM
TUMBLEWEEDTURKEY
  • 5 POSTS
thanks
Sep 16, 2010 at 7:30 AM
WRENCHTECH
  • 20,761 POSTS
You can verify what I said if the 8th digit of your VIN# is a 3
Sep 16, 2010 at 7:32 AM
