1963 Other Ford Models starting an old engine
JUNGLE_VROOM
  • 1963 FORD
Engine Mechanical problem
1963 Other Ford Models 6 cyl Two Wheel Drive Automatic alot miles
Hey guys,
I have an old 1963 ford falcon 250 6 cyl.
I have had it stored for about three years and I have not ever started the engine.
can anyone suggest the steps or a checklist I should go through before starting her up again?
Sunday, August 31st, 2008 AT 12:32 AM
  • 31,937 POSTS
Hi there drain the oil & change the filter, pull the plugs and squirt engine oil down each bore, re fill oil & prime filter, crank engine with out plugs until oil pressure is up. Check points, leads, cap, rotor, change air & fuel filter. The carby may be full of corrosion so may be lift the top and inspect, or better still o/haul it. Change the coolant & thermostat and you should be set for a run.
Mark (mhpautos)
Sunday, August 31st, 2008 AT 3:31 AM
