1988 Ford Mustang No Crank Clicking
TOT11
I have a 1988 Ford Mustang Four Cyl. I have replaced the alternator and Solenoid switch but it still will not crank. It won't even try to turn over. Could it be the battery or is it something else??? Please reply if you know the answer.
Jun 2, 2007 at 8:23 AM
98RANGERXLT
  • 301 POSTS
Charge the battery and try it.
Jun 2, 2007 at 9:40 AM
TOT11
I have charged the battery and it still will not turn over. When i try to start it it makes a clicking noise in the solenoid. Please reply if you know what is wrong.
Jun 3, 2007 at 8:25 AM
MERLIN2021
  • 17,250 POSTS
Clean or replace the battery cables.
Jun 3, 2007 at 8:27 AM
TOT11
Ok i've clean them, but the clicking in the solenoid....does it mean that it is working properly???
Jun 3, 2007 at 8:31 AM
GARG
Did you clean all the cables?
Ford is bad about if the starter doent get enough volts it does the same thing.
I had the same problem and parts store manager told me this and i changed all the cables and it fixed my problem.
Have you had the starter checked?
Jun 5, 2007 at 5:21 PM
Suggested Repair
With the battery already charged, clean or replace the battery cables so the starter gets full voltage. A solenoid click without cranking often means poor cable connections or cables that still need replacement.
Conversation Summary
The owner of a 1988 Ford Mustang four-cylinder said it would not crank after the alternator and solenoid were replaced. Charging the battery did not help, and trying to start it only produced a click at the solenoid. An expert advised cleaning or replacing the battery cables. The owner cleaned them and asked whether the click meant the solenoid was working; no further expert reply confirmed the next step.
