standard trany fluid
YELLOW MUSTANG
2002 Mustang
4.6L SOHC
5 Speed T45
94,000 Miles
The owners manual says to use Synthetic Mercon III ATF fluid for the standard transmission. The Haynes Manual says to use Mercon III ATF. The Service Department of the local Ford Dealer says to use Mercon V. Which is the appropriate fluid to use in the T45 standard transmission?
Oct 24, 2007 at 1:18 AM
  • 75,988 POSTS
Stick with this > The owners manual says to use Synthetic Mercon III ATF fluid for the standard transmission.
How long ago was the last transmission service and what fluid was used?
Oct 27, 2007 at 8:41 AM
