2002 Ford Mustang Manual Trans Fluid
YELLOW MUSTANG
2002 Mustang
4.6L SOHC
5 Speed T45
94,000 Miles
The owners manual says to use Synthetic Mercon III ATF fluid for the standard transmission. The Haynes Manual says to use Mercon III ATF. The Service Department of the local Ford Dealer says to use Mercon V. Which is the appropriate fluid to use in the T45 standard transmission?
Oct 24, 2007 at 1:18 AM
  • 75,988 POSTS
Stick with this > The owners manual says to use Synthetic Mercon III ATF fluid for the standard transmission.
How long ago was the last transmission service and what fluid was used?
Oct 27, 2007 at 8:41 AM
Suggested Repair
Use synthetic Mercon III ATF in the T45 as specified in the owner's manual. Note when the transmission was last serviced and which fluid was used.
Conversation Summary
The owner of a 2002 Ford Mustang with a T45 five-speed received conflicting fluid recommendations: synthetic Mercon III from the owner's manual, Mercon III from Haynes, and Mercon V from a Ford dealer. The expert advised following the owner's manual and asked about the last transmission service and fluid used.
