2001 Ford Mustang Service Engine Light
The Fords seem to have a DPFE problem, although I would jump to that. What code is now showing?
Jun 9, 2007 at 4:47 AM
what is a DPFE problem ? I haven't had it checked again yet I figured I would take it to a Ford dealer and have them check it out. I originaly had taken it to Oreiley's auto parts. Don't know if I trust them now.
Jun 9, 2007 at 8:03 AM
Delta PRessure Feedback of Egr.
I don't know that I would trust the dealer any different.
Jun 9, 2007 at 8:24 AM
If it's a P0401 clean the port under the EGR all the way thru to the throttle bore, I use a steel coathanger. Clear the codes, if light comes back on replace the EGR position sensor...
Jun 10, 2007 at 1:35 AM
Suggested Repair
Confirm the current code. If it is P0401, clean the EGR port all the way through to the throttle bore, clear the codes, and replace the EGR position sensor if the light returns. Also consider the DPFE sensor, which is a common Ford EGR-related failure.
Conversation Summary
A 2001 Ford Mustang V6 had a service engine soon light. An EGR valve was replaced after a parts-store check, but the light returned. An expert asked for the current code and explained that DPFE means Delta Pressure Feedback of EGR, a common Ford issue, while cautioning against jumping to that diagnosis. Another expert said that if the code is P0401, clean the port under the EGR through to the throttle bore, clear the codes, and replace the EGR position sensor if the light comes back.
