2000 Ford Mustang P0301 P0302 Misfire
WROTTDOG
2000 Mustang 6-cylinder with about 69k miles. Code reader shows both P0301 and P0302. Since the problem started quite suddenly, is it more likely to be a vacuum hose leak than a sparkplug or coil problem on two cylinders at the same time? Is there a way to find such a leak? Thanks.
Nov 17, 2006 at 2:41 PM
CATCH_15
  • 250 POSTS
One way to find a vaccuum leak is to take a bottle of brake cleaner and spray around the vaccuum hoses. If there is a leak in one of the hoses, it will suck some brake clean in and the engine will rev up. Hope this helps.
Nov 18, 2006 at 1:25 AM
Suggested Repair
With the engine running, spray brake cleaner around the vacuum hoses. If a hose is leaking, the engine will draw in cleaner and the RPM will rise, identifying the leak.
Conversation Summary
A 2000 Ford Mustang 6-cylinder with about 69,000 miles suddenly set P0301 and P0302 misfire codes. The owner asked whether a vacuum hose leak was more likely than plugs or coils on two cylinders at once and how to find a leak. The expert suggested spraying brake cleaner around the vacuum hoses; a leak will pull cleaner in and make the engine rev up.
