2000 Ford Mustang Cylinder Misfire
Wrottdog,
Need to know what size engine your car has in order to get the firing order. As far as changing the plugs do you know when they were last change. If you change the plugs and still get the codes I would next suspect the coil packs for #1 and #2 cylinders. I think your car has one for each cylinder.
Good luck Backyardmechanic
Nov 12, 2006 at 1:37 AM
It's a V6. I don't know its history. I bought it in June with 66k miles. It has about 69k now. If I need to change coils, I'll need to know the order of them as well. Thank you for your input.
Nov 12, 2006 at 1:53 AM
I suggest changing the plugs first. It's the least expensive and the car probably needs them. I don't know the order for the coils but here is how you can tell. Look at the front of the motor and see which cylinder head is closer to the front. One of them will be( May be hard to tell so look closely) closer to the front. This is the odd side cylinders (in this order) # 1,3,5 from front to back. The other side is the even cylinders # 2,4,6 from front to back. If the #1 and #2 cylinder are still misfiring after you change the plugs you may want to check the wiring to the coils before you go and change the coils. If you conclude it is the coils then you would have to change the front 2 (#1 and #2) 1 questionThe does the car run ok or doees it miss and if so is it all the time or intermittently.
Hope this helps
Hope this helps
Nov 12, 2006 at 5:24 AM
Thank you for your advice. It's running very rough to the point that I wondered if it would make it home the last time I drove it and the check engine light alternates between flashing and steady.
Nov 12, 2006 at 7:21 AM
🔧 Tools & Auto Repair Parts
Find automotive tools, diagnostic equipment, and replacement
parts for your next repair.
Shop on Amazon →
Suggested Repair
Change the spark plugs first. If cylinders 1 and 2 still misfire, inspect the coil wiring before replacing the front two coil packs. The head closer to the front is the odd bank (1, 3, 5 front to back); the other bank is even (2, 4, 6 front to back).
Conversation Summary
The owner of a 2000 Ford Mustang V6 with about 69,000 miles asked how the cylinders are numbered and whether spark plugs are the first step for P0301 and P0302 misfires. The expert recommended plugs first as the least expensive step, explained odd and even bank numbering from front to back, and advised checking coil wiring before replacing coils if the misfires continue. The owner later said the car runs very rough and the check engine light alternates between flashing and steady.
