1997 Ford Mustang code p0302
1997 FORD MUSTANG
CARLOSGQ
Engine Performance problem
1997 Ford Mustang 6 cyl Two Wheel Drive Automatic
got a code P0302 MANUAL SAYS CIL 2 MISSFIRED HOW CAN I FIXED THIS, IM UNEMPLOYED AT THIS MOMENT CAN AFFORD A MECHANIC RECENTLY REPLACED HEADS PLS HELP, THANKS
Oct 18, 2010 at 8:19 AM
JDL
  • 16,098 POSTS
How long since a tune-up? Visually check for spark at the plug, cylinder number2. Use a noid lite and check for injector pulse. You may also need to check cylinder compression?
Oct 18, 2010 at 8:29 AM
CARLOSGQ
tought of that and change sparks after changing went for a test drive and code came back again sound like a cil. not working is that related to replacing heads I could look at the warranty and take back to mech. Please let me if code can be related to new heads still under warranty if not anyway thanks a lot for your help you guys a a great help. Thanks!
Oct 18, 2010 at 8:49 AM
JDL
  • 16,098 POSTS
I can't say it is related to heads, but, possible.
Oct 19, 2010 at 2:32 AM
