2004 Ford Mustang Engine Knock Locked Up
BLEISTER
2004 Mach1 (32V) 37,000miles: I had a faint tick in my engine that the dealer "couldn't tell me what it was" now its past the warrenty and yesterday my battery died (after replacing it) and unrelated to that I believe. The ticking turned into a loud knocking and on my way home from work I lost horsepower then the car died. New battery is in it of course and everything works, but the engine wont turn or even try to, the starter almost engages but its like it is locked up. I have heard about knock sensors in these engines, and of course the knocking made me think oil, but Im unsure??? And the oil is good just not sure if it is going everywhere it should be. Any idea what could cause this?
Aug 8, 2007 at 12:32 AM
  • 31,937 POSTS
Hi there,
You may have a siezed engine, i would remove all the spark plugs and try to turn the motor by hand. At worst remove the starter motor andn use a large screw driver to try and turn the motor via the ring gear teeth. If you can't turn it or it turnes and stops, something has broken and you will have no option but to remove the engine for more detailed invistagation.
Mark (mhpautos)
Aug 8, 2007 at 11:08 AM
Suggested Repair
Suspect a seized engine. Remove the spark plugs and try to turn the engine by hand. If needed, remove the starter and try to turn the ring gear with a large screwdriver. If it will not turn or turns and then stops, something is broken and the engine must be removed for further inspection.
Conversation Summary
A 2004 Ford Mustang Mach 1 with about 37,000 miles developed a faint tick that became a loud knock. After losing power and stalling, the engine would not crank and felt locked even with a new battery. The expert said the engine may be seized and advised trying to turn it by hand with the spark plugs removed, or via the ring gear after removing the starter. If it will not turn freely, the engine needs to be removed for inspection.
