ignition problems
EDGAR1966
i have 1966 ford mustang coupe it started to give me problems .every time i try to turn on the car the starter stays stuck.recently i changed out the cellunoid,the starter,the alternator ,the battery.when ever i start the car i have to disconnet the battery because it will stay cranking or running.when i go to connect the terminals it gives a shock on both ends like if ihave a short somewhere.what could it be?
May 27, 2006 at 6:57 AM
LOSONE
  • 1,616 POSTS
You still have either a bad starter or a bad solonoid. Hopefully they are not Zone parts as you need good quality parts for your vintage car..
Make sure the little wires on the solonoid are on correctly I and S
Disconnect the small wire with an S and jump across to the + terminal on the solonoid with the key on. If it still does it be ready to tap the solonoid. If that doesn't do it replace the starter.
May 27, 2006 at 7:07 AM
