1995 Ford Mustang No Start
MEGAWATTS88
I have a 95 mustang, 3.8L v6. I have been having trouble with my car so I took it to the mechanic and he told me that I had a blown head gasket. Well me and a friend tore my motor apart and checked the gaskets and didnt see anything that would indicate any problems with the head gaskets. We replaced all the gaskets and put the motor back together. I started my car and it ran rough but it ran. After a couple of seconds it started to make a rather noisey popping sound. The sound was more of a air popping and didnt sound metallic at all. The engine soon began running rougher and then all the sudden stopped and I have not been able to start it since. I removed all the NEW spark plugs I had just put in when we put the motor back together and they looked just like the old plugs that had 30K plus miles on them. All except one plug which still looked brand new. I have no clue why the motor is doing this and I need help. The motor has 213K miles and I should probably get a new one but I was hoping i could fix it to get me through college.
Dec 9, 2006 at 12:37 PM
CATCH_15
  • 250 POSTS
When you had the heads off, did you take them to a machine shop to have them pressure tested and checked for warpage? It's always a good idea to do those things before you reassemble everything.
Dec 9, 2006 at 1:31 PM
MEGAWATTS88
I didnt take them to a machine shop. I cleaned them, replaced the seals, and visually checked for cracks.
Dec 9, 2006 at 1:43 PM
HEY_WIRE
  • 25 POSTS
when you reacembled the head gasket did you check to make sure nothing like rust or anything like that or anything at all (nuts bolts) had fallen inside and could clog things up from oil getting to the places it should be getting to?
i had a 76 chevy i had to replace the gaskets and there was quit a bit of rust and flakey paint around it i think fell inside the engine ran rough for about a week and i desided to change my oil it did the trick but i guess that could have been something totally different i dont really know
best of luck
Dec 9, 2006 at 4:09 PM
MEGAWATTS88
Thanks for the tips. I thought about compression testing the cylinders and see if they are holding compression or not. If they arent i will most likely dissassemble the block and have the heads checked.
Thanks.
Dec 9, 2006 at 4:55 PM
BOB G
  • 25 POSTS
Just a thought, when you completed the head gasket job, it's possible you crossed the spark plug wires, which will throw off your timing, check the firing order and make sure all the wires are going to the right plugs. One other thing with that high mileage on your vehicle, it's also possible the timing chain could have jumped, throwing your timing off. You'll need to do a compression check. If all cylinders have a poor reading, then it's the chain.If you have 2 weak cylinders that are side by side, thats usually an indication the head gasket is blown between the two cylinders. But check the firing order first.
Mar 28, 2007 at 6:50 AM
MCFERRANCE
  • 100 POSTS
Does the engine crank over at all? If not, can you turn it over by hand by putting a socket onto the crankshaft bolt and turning it with a breaker bar?
Mar 28, 2007 at 3:14 PM
Suggested Repair
Confirm the engine cranks and turns by hand, then verify the spark plug wire firing order. Perform a compression test: low readings on all cylinders can indicate a jumped timing chain, while two weak adjacent cylinders suggest a head gasket leak between them. If compression is poor, have the heads pressure-tested and checked for warpage or cracks.
Conversation Summary
The owner of a 1995 Ford Mustang 3.8L replaced the head gaskets after a blown-gasket diagnosis, but a visual check showed no obvious gasket damage. After reassembly the engine ran rough, made an air-like popping noise, then stalled and would not restart. The new plugs looked fouled except one. Experts recommended checking the firing order, compression, whether the engine turns, possible debris in oil passages, and having the heads checked for warpage and cracks.
