2003 Ford Mustang Coasting Noise
CONCRETEBEATZ
2003 Mustang GT 5sp
The problem with my car is when I’m cruising
in any gear and take my foot off the gas while
the car is in gear it while make a rattling/grinding/
scraping sound. If I give it gas it goes away or if I push the clutch in it goes away. The noise sounds like it’s in the rear one day and in the transmission next. I took it to the ford dealer and they claim it
was a problem with the rear, I had the rear rebuilt and the noise is still there. Any advice would be greatly appreciated. Thanks
May 12, 2006 at 5:38 PM
LOSONE
  • 1,616 POSTS
I can't tell from the description but it sounds like they didn't set up the ring and pinion correctly. It takes some special tools.
May 13, 2006 at 6:37 AM
Suggested Repair
Have the rear axle ring and pinion setup rechecked with the proper special tools. The noise remained after the rear rebuild and may be from incorrect gear setup.
Conversation Summary
The owner of a 2003 Ford Mustang GT reports a rattling, grinding, or scraping noise while coasting in any gear. The noise stops when the throttle is applied or the clutch is pressed. A dealer blamed the rear, but a rear rebuild did not fix it. The expert suspects the ring and pinion were not set up correctly and notes that special tools are required.
