1996 Ford Mustang Clutch Grinding Noise
SHEEKS88
I have a 96 Mustang GT clutch is making a grinding noise and when i put the clutch it makes a very loud screaching sound. After awhile it started to smell like burning ruber. does anyone no anything thanks
Sep 8, 2007 at 1:52 PM
  • 31,937 POSTS
Hi there,
Your clutch thrust bearing may be seizing, best way to check is to start the engine, slowly depress the clutch untill noise starts, you may feel a little vibration on the clutch pedal, if so the bearing in the thrust is failing, depressing the clutch all the way will normally not make the noise go away but as pressure increases the noise may alter. If noise is only present when clutch is operated the box will have to be removed to access clutch for repairs.
Mark (mhpautos)
Sep 8, 2007 at 5:40 PM
SHEEKS88
[quote:1c4bf8ff09="mhpautos"]Hi there,
Mark (mhpautos)[/quote:1c4bf8ff09]
hey thanks alot man
Sep 9, 2007 at 7:23 AM
Suggested Repair
Inspect the clutch thrust (release) bearing. With the engine running, slowly depress the clutch until the noise starts and note any pedal vibration, which points to a failing bearing. If the noise occurs only when the clutch is operated, remove the transmission to access and repair the clutch.
Conversation Summary
The owner of a 1996 Ford Mustang GT reported clutch grinding, a loud screech when pressing the clutch, and a burning rubber smell. The expert suggested a seizing clutch thrust bearing and a slow pedal-depression check; if the noise occurs only with clutch use, the transmission must be removed for clutch repairs. The owner thanked the expert.
