clutch
FORD MUSTANG
SHEEKS88
I have a 96 Mustang GT clutch is making a grinding noise and when i put the clutch it makes a very loud screaching sound. After awhile it started to smell like burning ruber. does anyone no anything thanks
Sep 8, 2007 at 1:52 PM
  • 31,937 POSTS
Hi there,
Your clutch thrust bearing may be seizing, best way to check is to start the engine, slowly depress the clutch untill noise starts, you may feel a little vibration on the clutch pedal, if so the bearing in the thrust is failing, depressing the clutch all the way will normally not make the noise go away but as pressure increases the noise may alter. If noise is only present when clutch is operated the box will have to be removed to access clutch for repairs.
Mark (mhpautos)
Sep 8, 2007 at 5:40 PM
SHEEKS88
[quote:1c4bf8ff09="mhpautos"]Hi there,
Mark (mhpautos)[/quote:1c4bf8ff09]
hey thanks alot man
Sep 9, 2007 at 7:23 AM
