2004 Ford Mustang No start
SOMKIAT HORTON
  • 2004 FORD MUSTANG
  • 6 CYL
  • FWD
  • MANUAL
  • 94,000 MILES
My 2004 Mustang will not start. It was working fine yesterday but this morning when I try to start it, it wouln't. The engine would crank but it will not turn over. Please help.
Thursday, October 21st, 2010 AT 7:46 AM
Cranks but no start condition-do below to determine whether it's a fuel or spark problem:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Sunday, October 24th, 2010 AT 11:55 PM
