I replaced my stock 10.6 inch rotors with used cobra calipers and 13 inch rotors and swapped the soft lines. The joint on the driver side where the soft lines meet the hard lines is dripping when I apply pressure to the lines, would not bleeding the brakes have something to do with it leaking? What should I do? Buy new lines? Since the calipers are used, do you think the seals inside will give me problems in the future? It came with the drilled and slotted performance rotors, but they are a little worn. Do you know anywhere I can get them resurfaced? Do they really help that much with a stock car for day to day driving?
May 11, 2010 at 10:33 AM
