2003 Ford Mustang 2003 Mustang gt - Idle & Weak Accel..
46,650 MILES • V8 • 2WD • MANUAL
JM3945
Just a few days ago my mustang started to misfire on cylinder #3. When I fiirst start it up it idles fine. If i rev it up it will idle very low and rough like it wants to die and ends up smelling like its running rich. Since then i have changed the spark plugs on all cylinders, changed the oil and filter. I tired a new 'coil on plug' but that still did not help. Every time i scan the computer it either throws random codes, or none at all. Now my oil is milky white on my oil cap but not on the dipstick. Any help would be appreciated before i go to a service shop.
Mar 2, 2009 at 8:08 AM
  • 75,988 POSTS
Misfire at no. 3 -check compression and injector for that cyl.
Random misfire P0300 normally points to false air and bad fuel
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Also check the PCV system
Mar 2, 2009 at 8:30 AM
JM3945
[quote:6508da010d="rasmataz"]Misfire at no. 3 -check compression and injector for that cyl.
Also check the PCV system[/quote:6508da010d]
what about my oil cap having the milky substance on it?
Mar 2, 2009 at 9:15 AM
  • 75,988 POSTS
Its probably due to condensation-Check your positive crankcase ventilation valve system. Might want to replace the PCV valve.
If its leaking coolant in the crankcase it will mix with oil and turn into milk shake an dit will show on the stick If in doubt get it block and pressue tested
Mar 2, 2009 at 10:05 AM
