1988 Ford Mustang PLEASE HELP
IMPORTKILLER
  • 1988 FORD MUSTANG
Engine Mechanical problem
1988 Ford Mustang V8 Two Wheel Drive Manual
I have a 88 gt mustang that I need help with. Th e car will crank over but not fire. It getting fuel pressure, spark, compresion, air. I have changed the spark plugs, pick-up. I have though about changing computer. Please help I need this car to run asap. Thanks mark.
Wednesday, December 16th, 2009 AT 6:01 PM
  • 31,937 POSTS
Hi there, get a scan done to check for any unresolved fault codes, check the injectors are operating, start here.
Mark (mhpautos)
Thursday, December 17th, 2009 AT 12:30 AM
BASSIST9693
  • 5 POSTS
Is the computer the original with the engine? I would also check you idle control unit on the intake. I have the same year and I had to replace it. If it is not functional the car will not get the proper air/fuel mixture upon crank, and it may not start. That may not be the problem, but it may be.
Tuesday, December 22nd, 2009 AT 6:31 PM
