HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Mustang
Warning Lights
Check Engine Light
2002 Ford Mustang RED CHECK FUEL CUP LIGHT ON
OSCARU
MEMBER
2002 FORD MUSTANG
6 CYL
2WD
AUTOMATIC
44,000 MILES
Just purchased car 2 months ago.
Driving to work and a RED CHECK FUEL CUP light came on.
What do I need to correct/fix? Car is still drivable.
Thursday, February 11th, 2010 AT 9:39 AM
SERVICE WRITER
MECHANIC
Look at the condition of the gasket around the fuel cap. Cracked or?
Look at the feul tank filler neck where the cap seal against. IS it clean or a little corroded?
Thursday, February 11th, 2010 AT 10:04 AM
Please
login
or
register
to post a reply.
Related Check Engine Light Content
Service Engine Soon Light.
On A 2002 Ford Mustang V6 5speed Replaced A Egr Valve And Solve The Service Engine Light For About A 2 Months And Recently Drive For About...
Asked by
sebastian rangel
2002
FORD MUSTANG
VIDEO
How to Read Codes
Instructional repair video
GUIDE
Check Engine Light
Why is my check engine or service engine soon turned on? In this guide we talk about what this is associated with this notorious light, what it is used for and what you...
2000 Ford Mustang No Engine Light!
I Have An Intermittent Stumble. I Have Idle Throttle Snap Hesitation. Vehicle Has A Manual Transmission And My Rpms Are Very Slow To Drop. I...
Asked by
hastewin
1 IMAGE
2000
FORD MUSTANG
1997 Ford Mustang Intermittent Check Engine Light
The Mustang In Question Recently Had A Situation In Which One Of The Spark Plug Wires Ended Up Being Burned Through. At The Same Time, We...
Asked by
tuneman2
1 ANSWER
1997
FORD MUSTANG
1996 Ford Mustang Check Engine Light
I Got The Code Po174 From A Check Engine Light Test And I Know It Means Bank 2 Is Too Lean. So I Cleaned The Maf With Quick-dry Electrical...
Asked by
cookgc1
1 ANSWER
1996
FORD MUSTANG
2009 Ford Mustang Throttle Body/check Engine Light
I Recently Installed A 70mm Bbk Throttle Body And My Check Engine Light Came On. There Is Almost Like A Whistling Noise As I Accelerate....
Asked by
derricka1350
1 ANSWER
2009
FORD MUSTANG
VIEW MORE
Code Read Retrieval/Clear - Dodge Stratus
Code Read Retrieval/Clear Mercedes Benz
Code Read Retrieval/Clear Mercedes-Benz C230
