2002 Ford Mustang
MONIREY16
  • 2002 FORD MUSTANG
2002 Ford Mustang V8
well I got a 2002 mustang gt. Well I dnt know what is wrong with it and im trying to fix it. Well when you first turn on the car and start driving it takes a long time to go fast. Also when im a stop sign or stop light and I been their for awhile and try to drive off it takes a long time to go fast. Even when I push the gas so I can run it goes slow and then it goes fast. This happens sometimes when the gas is on 1/4 of gas or full tank. When it wants the car goes fast. But once the car starts off slow n catchs its speed its okay. So I need help thanks
Wednesday, September 15th, 2010 AT 1:06 AM
KEVIN12881
  • 336 POSTS
Does it ever get up and go fast with no problem? So much can cause a loss in HP and you do not want to just through money into it, but there are some easy things to check and many things you can do that will not be a waste of cash. How is the air filter, how many miles are on it?
Wednesday, September 15th, 2010 AT 1:10 AM
MONIREY16
Well no it takes forever to fast when it wants it goes fast. The air filter im buying a new one and and im not sure how many miles are on the car
Wednesday, September 15th, 2010 AT 1:17 AM
KEVIN12881
  • 336 POSTS
I can sit hear for some time trying to tell ways to increase the power, but I could be wrong and just having you waste money. Without knowing what it needs im shooting in the dark, but depending on where you live and how friendly the area is you may be able to go to advanced or auto zone, or any parts place and tell them you car is lacking power. Both advaced and auto will hook up a compuer to your car for free to see if any codes pop up. Some will also take a little look and tell you what the car may or may not need. Could be plugs, wires, fuel fliters, o2 sensors, could need injector cleaner, or what not. Most of these things are cheap and not a waste of money, just dont go throwing too much money in it till you know what it needs.
Wednesday, September 15th, 2010 AT 1:35 AM
