1999 Ford Mustang Will not start
GILBERTASHOFF
  • 1999 FORD MUSTANG
  • V8
  • 90,000 MILES
We have checked all fuses all ok and all computer codes appear correct. Engine ran fine after changing antifreeze then would not start.
We suspect an anti theft problem but not sure what to do.
Car is in great shape and has never had this problem. Starter cranks normally and engine always fiored almst immediately.
Any help is appreciated.
Thank you
Gilbert
Monday, March 22nd, 2010 AT 10:38 PM
RACEFAN966
  • 5,029 POSTS
Ok before going to the security system which I don't suspect to be you problem yet. I need to know if there is spark and fuel. Now what I need you to do is unplug a spark plug wire from a spark plug no matter which one, now put a philips screw driver in the end and put it near the valve cover or other metal and crank it is there spark? Get back to me with that and we will check for fuel next if the spark is good.
Tuesday, March 23rd, 2010 AT 9:58 AM
