So my car stalls sometimes while im stopping and when i start it the rpms jump up and down not to mention if i turn the air on it drops my rpms almost enough to stalll it. can anyone can i help
SPONSORED LINKS
Tuesday, March 4th, 2008 AT 1:50 PM
2CARPRO JACK
MECHANIC
Try cleaning the Idle Air Control Motor. Also clean out around the butterfly in the throttle bore with carb cleaner and a rag. This should help stabilize the idle. If not you may need a new IAC
