1999 Ford Mustang fluid and hydrolic oil
DAYALA
  • 1999 FORD MUSTANG
  • 6 CYL
  • MANUAL
  • 140,000 MILES
How do I check and change the trasmition fluid and the hydrolic oil for the clutch?
Tuesday, November 18th, 2008 AT 12:38 PM
TEAG
  • 158 POSTS
On your transmission you should have 2 plugs on it. The one on the top is the filler plug and the one on the bottom is the drain plug. The operating level is just below the fill hole. You can check this by sticking your finger in the fill hole.
Wednesday, November 19th, 2008 AT 11:40 AM
DAYALA
  • 6 POSTS
About how much fluid would I need to fill once I drain it? Does the clutch have a seperate oil cylider that needs to be checked or is it all tied up with trans fluid?
Wednesday, November 19th, 2008 AT 12:03 PM
TEAG
  • 158 POSTS
Any fluid that is need for the manual transmission is all put in through the fill hole. It depends on what kind of transmission you have as far as how much fluid. A T-5 takes 5.6 quarts and a T-45 takes 6.6 quarts. If your not sure. You might want to get 7 quarts to be safe. The best way is to just keep filling until it starts to run back out. When it stops running back out, its filled to the best operating level. Thats pretty much it for the basic transmission servicing. Hope that helps you out. Good Luck!
Teagen
Wednesday, November 19th, 2008 AT 1:53 PM
DAYALA
  • 6 POSTS
Thanks this should help me out.
Wednesday, November 19th, 2008 AT 2:15 PM
TEAG
  • 158 POSTS
Great! Im glad to hear that. Hope everything goes nice and smooth for ya. If you have any more problems feel free to hit me up. Happy Wrenchin' :)
Wednesday, November 19th, 2008 AT 2:27 PM
