HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Mustang
Engine
Symptoms
Not Cranking Over
1998 Ford Mustang help
LARRYOE
MEMBER
1998 FORD MUSTANG
6 CYL
2WD
AUTOMATIC
140,000 MILES
The car won't crank
Saturday, February 20th, 2010 AT 9:17 PM
MECHANIC
No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
SPONSORED LINKS
Saturday, February 20th, 2010 AT 11:45 PM
Please
login
or
register
to post a reply.
Related Engine Not Cranking Over Content
1998 Ford Mustang Starter Problems..
Electrical Problem 1998 Ford Mustang V8 Two Wheel Drive Automatic I Bought A 1998 Mustang Gt That Was Salvaged With Some Seriously...
Asked by
TyrelW
1 ANSWER
1998
FORD MUSTANG
GUIDE
Starter Not Working
This guide is designed to help you identify whether the issue with your non-working starter motor is due to an electrical problem or a fault within the starter motor itself...
Engine Will Not Crank Over?
Car Was Fine, Then It Suddenly Would Not Start. The Battery Is Fine, No Clicking, But It Will Not Crank At All. Unfortunately, This...
Asked by
Shayne Canady
1 IMAGE
2001
FORD MUSTANG
Engine Wont Turn Over At All, When I Turn To Ignition...
Hi, I Am A New Ford Owner And Bought This Car Second Hand And Was Running Fine Once I Got It And Then About Five Months Or So Later, It...
Asked by
BigMike101
1 ANSWER
1983
FORD MUSTANG
Wont Start, No Crank, Happens Randomly
Bought Car 2 Months Ago. After 2 Weeks, Wouldnt Start After Driving Awile. Started After 5 Or So Minutes. Week Later, Same Thing, Except...
Asked by
techmastersean
1997
FORD MUSTANG
Will Not Crank
I Place Two Different New Batteries In Car. On The Last Battery Put In It Cranked Twice, Then It Clicked Then It Died. Will Crank With A...
Asked by
Laura Sellars
1999
FORD MUSTANG
VIEW MORE
SPONSORED LINKS
Battery Replacement Toyota
Battery Replacement Honda
Battery Test
Online car repair manuals
