Will not crank
LAURA SELLARS
  • 1999 FORD MUSTANG
  • 3.8L
  • 6 CYL
  • 71,000 MILES
I place two different new batteries in car. On the last battery put in it cranked twice, then it clicked then it died. Will crank with a jump off. There not a car with a lock on it showing on the dash. Does that show up if I have to reset the security system. Or that's not on a 1999 mustang
Sunday, March 5th, 2017 AT 6:38 AM
CJ MEDEVAC
  • 11,005 POSTS
Since a Jump Start would make it crank up and run,
Seems that would sorta rule out a security issue.
Sounds to me like dirty/ loose connections (my best guess) or the battery itself (even new stuff can be bad)
The Medic
Monday, March 6th, 2017 AT 7:42 PM
LAURA SELLARS
Well what ever it is just short makes me think the battery is bad.
Tuesday, March 7th, 2017 AT 10:58 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
Hey LAURA,
Here is a perfect test for you to see if the battery is nay good,
Best, Ken
Friday, March 10th, 2017 AT 11:04 AM
LAURA SELLARS
Okay I went to the Dealership today they told me my car was fix. Bad cable ends that go on the battery. They replace them said now it will crank. So I went out side way they crank it for me with the key. I paid them $ 57.00 for fixing it. Then I told them I was going to let it sit there till Monday that way I will know it is fix. Each day they are going to go out there try it to make sure it is fix too. Tuesday I have to go out town for work. Thank you all for your help.
Friday, March 10th, 2017 AT 4:32 PM
KEN L
  • 48,363 POSTS
Glad you could get it fixed please use 2CarPros. Com anytime we are here to help
Best, Ken
Monday, March 13th, 2017 AT 11:53 AM
