Other Category problem
1998 Ford Mustang Engine Size unknown Wheel Drive Type unknown Automatic 16028 miles
Car won't start. Everything turns on. Radio, lights, and windows work but the car won't start.
Monday, February 18th, 2008 AT 11:16 PM
BLACKOP555
MECHANIC
Will the vehicle crank?
Or does it sit there and click or make no sounds what-so-ever when its in the crank position.
SPONSORED LINKS
Tuesday, February 19th, 2008 AT 7:18 AM
RCBUCHANAN
MEMBER
No, the car wont crank. Everything turns on, except the engine. It doesn't make any noise at all. Please help, I know next to nothing about cars. Please reply, ask as many questions as you need.
Tuesday, February 19th, 2008 AT 3:32 PM
BLACKOP555
MECHANIC
Check for corroded and loose battery connections on the battery, starter relay, and the starter.
In that case remove the starter and take it in to a autopart store and have it tested, if its good put back on and replace the starter relay/solenoid. If that is still not the problem then you may have a bad ignition switch.
