1998 Ford Mustang Engine Problem
106,000 MILES • 6 CYL • 2WD • AUTOMATIC
GENESIS730
I just bought a 1998 Mustang from someone about 100 miles away, drove it for about 3 1/2 hours to get it home without a problem, no overheating, no low oil pressure, nothing even though there was check engine light on. The car seems to shake when it's idleing and my dad said it was because of a misfire. A few days ago we used his OBD-II tester and it showed two codes, one was Cyl. #2 misfire, the other was because it had overheated in the past. I changed the spark plug as well as the wire and it hasn't resolved anything. My dad said it could also be a bad head gasket. There's no funny exhaust such as white smoke. Only problem I find is the car doesn't seem to have the power it should. Any help would be great. Thanks
Sep 10, 2010 at 12:33 PM
  • 75,988 POSTS
You have replaced the plug on no.2-now you check the compression and injector for that cylinder
Sep 10, 2010 at 12:37 PM
GENESIS730
[quote:df9243f1fc="rasmataz"]You have replaced the plug on no.2-now you check the compression and injector for that cylinder[/quote:df9243f1fc]
Could it be anything other than than that??
Sep 10, 2010 at 12:52 PM
  • 75,988 POSTS
You need to check it to rule it out
Sep 10, 2010 at 4:46 PM
