1998 Ford Mustang Engine not starting
NGD05
  • 1998 FORD MUSTANG
  • V8
  • MANUAL
  • 86,000 MILES
Car has fuel in the fuel rail and new sparkplugs, but car just cranks and does not start. I think it is the fuel pump but am not sure
Monday, May 26th, 2008 AT 4:55 PM
When you turn key to run-do you hear the fuel pump-if so check fuel pressure and comeback with the readings. If not could be a fuse/fuel pump relay/inertia switch and computer.
Or do below immediately when it acts up
If the engine's condition is in tip top shape-do below to determine if its fuel or spark problem that's if its cranking over and refuses to start
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Monday, May 26th, 2008 AT 5:17 PM
