1998 Ford Mustang BREAK LIGHTS
163,000 MILES • 4 CYL • FWD • AUTOMATIC
JULIETEBUG
Today, I went to have my oil changed and the tech told me that ALL of my break lights are out. i still have tail lights. I am wondering if it is a Fuze that is blown since it is more than just one light out, or if all of them have blown.
I recently changed out a tail light bulb about 3 weeks ago and all of them were working at the time.
May 9, 2008 at 8:52 AM
  • 75,988 POSTS
Check fuse no.9 15amp fuse and the brake pedal position switch at the brake pedal support this 2 okay test the multi function/combination switch. You should have power at the multi function switch connector at the light green and orange wire while brake is depress. Nothing there the switch is defective
Its not the ground wire bcuz if it is-the other lights will not come On they share the same ground wire-
May 9, 2008 at 10:38 AM
