1997 Ford Mustang No Brake Lights (Lower). Have (Top) Bar
1997 FORD MUSTANG
DAD9INE
Electrical problem
1997 Ford Mustang 6 cyl Two Wheel Drive Manual
I have replaced the Brake Light Switch, Replaced the Combination (Hazzard, Turn, Emergency,Wipers) Switch. Still No Brake Lights. No Brake Lights - a answere in carpors made reference to the Body Control Module for Lights. I cannot find any BCM for the Mustang...Does it have one? Thanks earln
Aug 11, 2010 at 4:18 PM
BLUELIGHTNIN6
  • 16,542 POSTS
did you check basics? (i.e fuses, bulbs, wiring)
your mustang has a powertrain control module (PCM) , no body control module. the brake lights do not run through your PCM though. will need to check for power at the brake switch.
Aug 11, 2010 at 4:23 PM
