1998 Ford Mustang
JACKSANDY0804
  • 1998 FORD MUSTANG
  • V8
  • MANUAL
  • 140 MILES
My car has been running sluggish for a few days then today it stopped and when up put it in to gear it wont move it will start and go into gear it just wont move sounds like its in neutral
Wednesday, June 30th, 2010 AT 3:49 PM
RICHZOMBIE
  • 173 POSTS
If the engine is running, but the car won't move when you put the transmission selector in gear, follow these steps:
Automatic Transmission
: If you place the selector in Drive or Reverse, but the engine just races when you step on the gas and the car does not move or moves very slowly, it means that there is a problem with the transmission or driveline
. First thing to do is check the fluid level in the transmission. In most cars, you check the transmission fluid level with the engine running in Park. If the fluid level is very low, in short, you see no fluid on the dipstick, shut off the engine to avoid further damage to the transmission and call for a tow to a repair shop. In some cases, a leak can be repaired fairly easily without a large expense (assuming the transmission wasn't damaged by running with low fluid levels). If the fluid is full, there is a slight chance that the gearshift may have come disconnected, which means that you lucked out. Otherwise, you are most likely facing an expensive transmission rebuild.
Wednesday, June 30th, 2010 AT 11:00 PM
