I just replaced my speedometer on my 1997 mustang, and now it won't start. The theft light keeps flashing. Someone please help.
Friday, June 4th, 2010 AT 10:31 PM
BLUELIGHTNIN6
MECHANIC
We answer thousands of questions everyday so Im sorry you feel we are unresponsive
When you say you replaced the speedo, do you mean the entire gauge cluster assembly or just the speedo/tach assembly from the cluster? Is the engine cranking at all or getting no response from ignition switch?
SPONSORED LINKS
Monday, June 7th, 2010 AT 7:25 PM
YKKRS
MEMBER
I just replaced the speedo/tach, cluster. It will crank but won't start.
Tuesday, June 8th, 2010 AT 12:56 AM
BLUELIGHTNIN6
MECHANIC
If it's cranking then wouldn't have anything to do with speedo replacement I wouldn't think. Need to make sure fuel pump is coming on and fuel pressure is correct. If OK check spark plugs to ensure they are getting bright blue healthy spark
Tuesday, June 8th, 2010 AT 3:05 PM
YKKRS
MEMBER
How would the fuel pump make the theft light flash like crazy?
Thursday, June 10th, 2010 AT 12:52 PM
BLUELIGHTNIN6
MECHANIC
Didn't notice the anti theft light flashing. First make sure fuses are good, especially the maxi fuses under hood. If OK, try using a different key. If that doesn't work than the original key may need reprogammed as well as the PATS system, that is the anti theft system Ford uses.
SPONSORED LINKS
Thursday, June 10th, 2010 AT 1:04 PM
YKKRS
MEMBER
O.K. I got new keys-pats, reprogrammed keys and still won't start. This theft thingy is driving me crazy.
Friday, June 11th, 2010 AT 4:28 PM
BLUELIGHTNIN6
MECHANIC
Pull the fuse to the theft system out and try cranking then
Friday, June 11th, 2010 AT 5:52 PM
YKKRS
MEMBER
You left out something during your reply. Pull the fuse and?
Friday, June 11th, 2010 AT 6:15 PM
BLUELIGHTNIN6
MECHANIC
Nope, it's all there on my screen? I posted pull the fuse to the anti theft system and then try cranking engine
Friday, June 11th, 2010 AT 6:17 PM
YKKRS
MEMBER
O.K. Tried that, it just cranks
Friday, June 11th, 2010 AT 6:21 PM
BLUELIGHTNIN6
MECHANIC
If the key is good then the computer must be at fault. Best bet would just be having a diagnostic ran on the anti theft system at local shop
Friday, June 11th, 2010 AT 7:16 PM
YKKRS
MEMBER
Is there a way to check a pats key if it's any good? By the way the nearest ford dealership is about three hundred miles from here.
SPONSORED LINKS
Saturday, June 12th, 2010 AT 4:23 PM
BLUELIGHTNIN6
MECHANIC
Any local locksmiths around? They could tell you if the key is good or not
Tuesday, June 15th, 2010 AT 12:18 PM
YKKRS
MEMBER
Unfortunately there are no locksmiths around here. This thing is driving me crazy, I tried a obd code reader, but it won't read anything.
