I just noticed that when I disconnected the fan connector and I turn the key to the ON position the fuel pump doesnt upload, you know the noise that it always makes when you turn your key to ON position it makes the noise of starting or preloading before you actually crank up the engine with your key, but when I looked at the fuse under the hood which is a 20A it looks good and I was checking it with a ohm meter on 200ohms setting and it has passege as in it goes to zero when I touched the two metal prongs on the fuse itself, is there another fuse for a fuel pump under the hood of the car that is seperate from other fuse boxes and maybe its somewhere on the firewall or under car, also I have other cars at home here and when I looked at them under I see a mesh style ground wire going to the exhaust from chassie and engine block as well as transmition to chassie, my mustang doesnt have those underneeth is that a big deal, and can it cause different voltages to be send throughout the car if the engine block is not grounded with that wire to the chassie. By the way I really appreciate your help and troubleshooting suggestions, all I want for now is for this car to start like it did before I tested the sensor yesterday I was driving it and the only problem I was having was the check engine light and I obviously made a wrong choice by testing it again, hahaa.
Friday, June 6th, 2008 AT 12:05 PM
