HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Mustang
Engine Cooling
Water Pump
Pulley
SPONSORED LINKS
1996 Ford Mustang
LENTINA
MEMBER
1996 FORD MUSTANG
Engine Mechanical problem
1996 Ford Mustang 6 cyl Automatic
I have a 96 mustang and I am taking the water pump off but the power sterring pump pully is in the way how do I remove it
Thursday, September 18th, 2008 AT 5:57 PM
BLACKOP555
MECHANIC
You can choose to remove the pulley or you can choose to loosen the power sttering pump and move it out of the way so you can get the water pump off.
I suggest loosing the pump and moving it out of the way over removing the pulley.
SPONSORED LINKS
Thursday, September 18th, 2008 AT 6:35 PM
Please
login
or
register
to post a reply.
Related Water Pump Pulley Content
1996 Mustang, 3.6 Liters, Split 6
Car Is Over Heating. I Replaced The Thermostat This Morning, But How Does Check To Make Sure The Water Pump Is Ok?
Asked by
GradyF
1 ANSWER
1996
FORD MUSTANG
Coolant Bypass Removal From Water Pump
The Heading Of This Question Is Pretty Much It. I Finally Got The Pulley Puller And Took The Power Steering Pump Pulley Off. I Have...
Asked by
Jonathan Wolbert
1 ANSWER
1 IMAGE
1995
FORD MUSTANG
1965 Ford Mustang Water Pump Replacement
Where Can I Get Step By Stpe Instructions To Replace A Waterpump With Broken Bolts For A 1965 Ford Mustang?
Asked by
jbertolone
1 ANSWER
1965
FORD MUSTANG
Coolant Metal Bypass
I Changed My Water Pump Recently But Bent The Metal Tube That Goes Into The Top Of The Water Pump. I Tried To Bend It Back Into Its...
Asked by
sugar132plumb
1 ANSWER
1 IMAGE
2000
FORD MUSTANG
2000 Ford Mustang
I Have Replaced The Water Pump And Thermostat. I Still Have No Water Circulation, No Heat, But The Car Does Not Overheat. Sugestions?
Asked by
jbyram
1 ANSWER
2000
FORD MUSTANG
VIEW MORE
SPONSORED LINKS
Coolant Leak Repair
Cooling System Pressure Test
Online car repair manuals
