1995 Mustang manual transmission
SPONGE27
  • 1995 FORD MUSTANG
I have about 120000 miles on my 1995 Mustang 3.8ltr car. Lately Ive been having more and more trouble shifting gears. The problem seems happen only when im shifiting into 1st, 2nd, and reverse gears. But the the most constant problem is upshifting from 1st to second gear when Im driving. Is this a sign that I need a new clutch?
Monday, February 27th, 2006 AT 6:03 PM
LOVESCARS
  • 359 POSTS
Check lower bell housing for fluid leak---check the clutch master cyl also for fluid level. Sounds like the slave cylinder is going and I recommend you replace everything in there if you disassemble. Resurface the flywheel as well.
FORD CLUTCHES ARE A PISSER TO BLEED BE FORWARNED
Monday, February 27th, 2006 AT 8:24 PM
