HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Mustang
Drivetrain
Transmission
Clutch
SPONSORED LINKS
1999 Ford Mustang clutch
HENRYCJ
MEMBER
1999 FORD MUSTANG
Noises problem
1999 Ford Mustang Manual
clutch makes a high pitched squeal when it is engaged
Monday, May 10th, 2010 AT 7:17 PM
MECHANIC
Hi there, can you feel anything through the clutch pedal? Often this is a faulty clutch thrust bearing.
Mark (mhpautos)
SPONSORED LINKS
Tuesday, May 11th, 2010 AT 3:08 AM
ERIOLSETSFIRE
MEMBER
1 POST
How much does it cost to change it out?
Tuesday, June 29th, 2010 AT 8:35 AM
MECHANIC
Bearing approx $45.00
Labour approx 4Hrs at local rate.
Mark (mhpautos)
Tuesday, June 29th, 2010 AT 8:49 AM
Please
login
or
register
to post a reply.
Related Transmission Clutch Content
1999 Ford Mustang Clutch
I've Got A 99 Mustang Gt And Im Trying To Buy A Upgraded Clutch With A Throwout Bearing? My Car Is Basically Stock So I Believe It Has A 10...
Asked by
rb4405
1 ANSWER
1999
FORD MUSTANG
VIDEO
How to Check Your Clutch Operation?
Instructional repair video
GUIDE
Clutch Replacement
Before you replace your clutch its a good idea to see how the clutch works and the symptoms of a bad clutch. A clutch will have problems and can stop working all...
Makes Lots Of Noises When Depressing Clutch, Not When It Is Idling.
Asked by
shakado1
1 ANSWER
1999
FORD MUSTANG
2001 Ford Mustang Engine Revs When Clutch Is...
I've Found That While Driving In Traffic And The Car Is Warm That The Engine Will Rev Up When I Depress The Clutch. This Is More Noticeable...
Asked by
giventofly
2001
FORD MUSTANG
2007 Ford Mustang Rattling Clutch
When The Car Is Cold And I Pull Off And Start Driving And I Blip The Throttle To 3k Rpm. I Hear This Rattling Sound From The Area Of Clutch
Asked by
ghostdog
2007
FORD MUSTANG
2001 Ford Mustang Clutch Is Stalling Car
Whenever I Slow Down And Push In The Clutch, The Rpm's Drop To About 500 Rpm. Very Rarely, The Car Will Actually Cut Off Completely And I...
Asked by
cdhedrick
2001
FORD MUSTANG
VIEW MORE
SPONSORED LINKS
Clutch and Throwout Bearing Front Wheel Drive
Clutch/Flywheel/Rear Main Seal Replacement
Online car repair manuals
