1995 Ford Mustang A couple of questions
113,500 MILES • 6 CYL • FWD • AUTOMATIC
JENNIFER3177
I noticed today that the oil pressure dropped to red when I was driving today. I got an oil change today, it it did the same thing. Also, my heat and air fan does not work, just a little heat comes on (no fan blowing) when my car is moving, and the air or heat will stop when I am stoped at a light. Thank you for your help.
Mar 3, 2009 at 3:50 PM
2CARPRO JACK
  • 11,533 POSTS
I would worry about the oil pressure problem first.Have a manual gauge installed to verify good pressure,if ok you are looking at either a bad gauge or sending unit. The fan. since it doesnt work at all, check the fuses first. If fuses are ok, need to remove panels under the passenger side of the dash to gain access to the motor.Use a test light to see if any power is getting to the motor, if it has power and ground the motor is bad.If nothing, test for power at the fan speed resistor next to the fan motor.if it has power in and nothing out itis most likely bad
Mar 4, 2009 at 12:03 AM
