1994 Ford Mustang Turn Signals Not Working
GABEATWORK
  • 1994 FORD MUSTANG
  • V8
  • 110,000 MILES
On my car, the turn signals don't work. The relay seems to be working, the fuses all seem to be okay. At night time I can kind of jiggle the turn signal lever to make them work manually. But it doesn't work all the time. I'm thinking it could be the switch itself maybe something else. If anyone would give me some help or suggestions, I would greatly appreciate it. If you have any questions or if I have not been specific enough feel free to contact me. Also keep in mind I barely have any knowledge about car repair. So if you could put your answer in laymens terms I'd appreciate that as well.
Tuesday, December 25th, 2007 AT 9:40 AM
SERVICE WRITER
  • 9,123 POSTS
It certainly sounds like a bad switch. If jiggling it seems to be affecting it, then I would plan on a switch. You can disassemble and check for a possible bad connection or wiring, but not likely.
Wednesday, December 26th, 2007 AT 4:41 AM
