1994 Ford Mustang Hard thud when near stop
57,000 MILES • V8 • 2WD • AUTOMATIC
DARYLS0107
When comming to a stop, the car has a loud thud; almost as if something is still moving forward like a load shift. It is difficult to tell exactly where it is comming from. Could this be due to a drive train issue? UV joint, yoke?
Jan 21, 2008 at 9:25 AM
SERVICE WRITER
  • 9,123 POSTS
May be a problem in one of the brake drum areas. Possible wheel cylinder or axle seal leaking. The brakes will usually feel grabby from this.
Jan 21, 2008 at 9:59 AM
DARYLS0107
I just replaced the brakes all around and new rotors. Problem is still present. In researching online, I have found other people talk about similar problem being due to the ujoints or the yoke spline not being properly lubed.
Jan 21, 2008 at 12:54 PM
