1994 Ford Mustang
MUSTANGKID3
  • 1994 FORD MUSTANG
Engine Mechanical problem
1994 Ford Mustang 6 cyl Two Wheel Drive Automatic
ok so I was driving my car on a hot day helping my friend move, and I was making my last round when my engine started making this sound, which sounded like bolts in the engine. I was on the freeway and then white smoke came from under the hood and my car was way over heated, but then my car wouldnt start again I got it towed and found out that my radiator was broken so I replaced that and bought a new battery yet my car still wont start, I have gas in the car and I have cleaned my battery connectors any suggestions?
Friday, August 21st, 2009 AT 10:21 PM
Check if you have coolant in the cylinders if so could be a blown headgasket, cracked head or block or an intake leak-Also check the oil if its milky or the coolant mixed with oil
Saturday, August 22nd, 2009 AT 12:37 AM
