I just want some more information before I fix these problems. I have a 1993 5.0 Mustang LX with 203k miles. The heater core started leaking, and I bypassed it about a year ago. I have gotten estimates of $500+ to fix it. Wow. I have gotten the jist that the AC system is wrapped around it somehow, so it will have to be drained and partly dismantled to reach the heater core. Also, the dash will need to be completely removed. Is this really true --- is there a simpler way? I read that other year mustangs have a panel in the glovebox that facilitates reaching the heater core. I wanted to suggest cutting any light panels instead of removing my dashboard to my mechanic. Opinions?
Also, two lesser problems I would like leads on:
1) My cruise control stopped working. Pressing the buttons does nothing now. I didn't find a fuse for this. Where should I look first? Is this only repairable by a mechanic?
2) The car does not cold idle anymore very well. This happened recently. I start the car in the morning, and it will stall unless I keep the RPM's up with my foot. It used to cold idle at 1100 rpm and then drop to 800 after a minute or if I shifted. During the day it does the same, just not as bad, as the weather is warmer. What could have caused this? What should I check?
Thanks for you help.
Victor
SPONSORED LINKS
Friday, October 19th, 2007 AT 6:54 PM
