1991 Ford Mustang 4 banger
VINCENT BURNS
  • 1991 FORD MUSTANG
I am having lots of trouble with just starting the car, I have changed out the Fuel pump and other items, I have run a computer check on it and it says the computer is the problem after changing out the other items first. Could this be the problem just change out the computer.
Wednesday, April 26th, 2006 AT 9:34 AM
THERASPER
  • 11 POSTS
First, to answer your question, yes, the PCM could be the problem, but lets not take that and run quite yet. Your post does not really detail exactly the problem, or the list of steps you have taken thus far. There are, with any problem such as this, a great number of things that could be the problem that are more common, and more probably the failure. I'd suggesst that you get ahold of a repair manual that has a diagnostic tree to follow, and follow the suggestions there to rule out the more common failures.
Best of luck to you.
Saturday, April 29th, 2006 AT 12:16 AM
CSTODD
If the car has hit a bad bump or something like that, there is a fuel pump reset switch in the trunk on the drivers side at the very back. It should be yellow.
I had this problem with a mustang and the pump had shut off after a bump.
Friday, May 19th, 2006 AT 5:05 PM
